TunerPro issue with compare function
Old Jan 17, 2007 | 01:28 PM
HaulnA$$'s Avatar
I searched but could'nt find anything on this. When comparing two .bins in TunerPro where there are two or more arguments in the conversion tab of the items definition, the data from the compare .bin isn't correct if the data in the second argument is different from the current .bin. For example, when comparing two timing tables where the main spark bias is different in each .bin, the compare .bins' data is not correct. It's like TunerPro is using the second argument in the definition, the bias in this case, from the original .bin only. Has anyone else come across this? Is there something I'm doing wrong? If so, I can't for the life of me figure it out. I have tried all different combinations in defining the item with no success. Any input is appreciated.
Old Jan 17, 2007 | 03:42 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Could be. I'll have to investigate.
Old Jan 18, 2007 | 04:29 PM
TUNGSTEN's Avatar
Engine: 355
Axle/Gears: 3.73 Trutrac
You need to change to the chip that you are comparing to. The top bar in Tunerpro needs to read the original chip and the compare chip same as the chips in the compare screen. Does this make sense? This Titanium from FSC BTW.
Old Jan 18, 2007 | 05:36 PM
HaulnA$$'s Avatar
I don't have a problem getting the .bins to compare or even to compare properly except when there are two arguments in the items conversion tab and one .bins second argument contains different data than the other. I'm not sure I'm explaining it well but I don't know how else to describe it.
Old Jan 22, 2007 | 11:20 AM
Mangus's Avatar
Transmission: T5WC
Bug confirmed. It doesn't actually have to do with 2 variables - it has to do with linking to another item's output.
I'll fix this and post a build shortly.
Old Jan 22, 2007 | 06:53 PM
884+3's Avatar
Car: 88 irocz
Engine: b2l 350
Transmission: corvette 4+3
Another minor problem ive had while emulating with an AutoProm is not getting the conformation beep when trying too modify the map multiplier settings in 8D bins. If i download the bin to check if the changes took place, i can make the changes and get the beep. But the bin file is corrupted and the check engine light comes on without setting an error code. Reuploading the entire bin corrects the problem. It also occurs with a few other settings.
Old Jan 22, 2007 | 07:43 PM
HaulnA$$'s Avatar
Thanks! And here I thought it was me.
Cornholio7979
Sep 20, 2018 02:31 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
beast94
Aug 20, 2015 06:44 AM
tmellott89
Aug 16, 2015 02:58 PM
mustangman65_79
Aug 11, 2015 03:17 PM
