odd stock parameters and checksum??
Old Feb 13, 2007 | 05:23 PM
longhorn450's Avatar
Car: 1990 Trans Am
Engine: LB9 305...350 or 383 coming soon
Axle/Gears: 4th gen 3.42
I finally picked up an Autoprom and i think its great. I cracked open my stock 7730 and read the bin and a few things just looked weird to me. I dont know if its like this with all stock bins or what. My TCC Coast Release was set to 255 mph. 3rd and 4th Gear TCC Locks were at 21mph and their unlocks were set to 20mph. AUJP TCC Coast Release is 32mph right?. <---What exactly does this table do??? Also why are these values so different?
Nevermind about the checksum part!!!
Thanks!!
Old Feb 13, 2007 | 11:24 PM
Car: 1990 Trans Am
I tried to start my car tonight with a stock AUJP bin and it would turn over but not start. It was also throwing an SES light. With the stock bin, with the key turned but with the car still off, the fuel pump would run for just a few seconds and then go silent. With the AUJP it would run forever....Why would it do that?? Also I noticed that the stock bins (AXYD) checksum was 764 while the AUJPs was 55515?? Should they be that far apart?
Old Feb 14, 2007 | 09:31 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Whenever trying a new BIN always check for the SES blink. No blink, don't even bother trying to start the engine. The SES blink is:
At key-on, engine-off, the SES will illuminate, blink off, then turn on solid. To check again, key-off or at least 5 seconds, then try again. No blink off means that the ECM is not running from the PROM. If there is a constant rapid flashing of the SES, the checksum is incorrect, or the PROM is burned incorrectly.
The checksums can vary, no problem with that.
If you are using an adaptor make sure everthing is plugged in correctly. Not off by a pin, and in the correct directions. The PROM plugs in with the notch/stripe/pin-1 toward the outside.
RBob.
Old Feb 14, 2007 | 10:39 PM
Car: 1990 Trans Am
man.... i feel dumb now. thanks RBob for that tid bit about the chip orientation in the adapter...i was putting in the same way that you would on the programmer towrds the zif handle. lol..anyways it works now. thanks again!
Ghettobird52
Jul 5, 2024 11:18 PM
Genopsyde
Oct 7, 2015 08:35 PM
Warlocksirix
Sep 3, 2015 12:26 PM
NufNuffZ28
Aug 14, 2015 09:12 AM
draco
Mid-West Region
Aug 10, 2015 09:18 PM
