Can't Data Log using Tuner Pro RT...
Old Feb 14, 2007 | 09:28 PM
WhiteIrocZ's Avatar
Car: 87 Iroc Z
I have a friend that has Tuner Pro RT and the OBD1 to USB hook up. He data logs his car, but we couldn't get it to work right with my car. It kept saying that it couldn't connect to my PCM. What are we doing wrong, because I am ordering a cable and have already got Tuner Pro RT, and I would like to start data logging. Any help is greatly appreciated.
Old Feb 15, 2007 | 01:16 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
What kind of car does he have? Remember you must have the right .ECU file loaded in TunerPro for it to recognize the computer in the car.
Old Feb 15, 2007 | 02:11 AM
sophinity's Avatar
Car: 1992 Miata
Axle/Gears: Ford IRS 8.8" 3.08
I am having the same issue and have been through tons and tons of things already am still tracking it down.
chime in if it still isn't working and also check here
https://www.thirdgen.org/forums/diy-...ng-7730-a.html
Old Feb 15, 2007 | 04:45 PM
WhiteIrocZ's Avatar
Car: 87 Iroc Z
He has a 1993 Trans Am LT1, but the cable is the same because it is OBD1 also. We downloaded the file from the site, but still no luck.
Old Feb 16, 2007 | 02:37 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
DA3 is the correct definition(s) to use for the vehicle.
Old Feb 18, 2007 | 07:55 AM
WhiteIrocZ's Avatar
Car: 87 Iroc Z
DA3 is the definition I need for my car right? It datalogs on his car, just not on mine, that is what we are trying to figure out. Where do I get this DA3 definition, I am new to this.
Falcon50
Aug 22, 2020 03:26 PM
tmellott89
Oct 14, 2015 02:06 PM
bjpotter
Oct 4, 2015 07:48 PM
djmarch
Oct 2, 2015 10:41 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
