So RBob, what's this MAT table algorithm that GrimReaper speaks of?
Old Mar 14, 2007 | 09:37 PM
ULTM8Z's Avatar
Originally Posted by Grim Reaper
Thanks. You should also read some follow-up done by RBob. When I came up with those changes, it was strictly by "trial & error" over the course of a year's driving in a wide range of temperature variations (-10*F to +105*F).
While the table worked well with my engine & mods, others have said that it "doesn't quite work" for them. It is dependent on a bunch of other variables and I assume that both of us have(had) probably similar (or relatively close) fuel pressure, fuel injectors etc.
However, I never quite figured out an "algorythm" (like I have derived for a number of other tables) so I could compute the changes necessary if a person had a vastly different set of specifications.
RBob has gone back and "re-visited" this and I believe he has a good "algorythm" so you can actually get that table exact for your application (instead of my 'trial & error' table).
But I'm glad it was able to work for you. I beleive that for ANYONE with an SD car and a relocated MAT, that table is a great place to start...definitely better than the stock MAT table.
From my MAT table thread...
Old Mar 15, 2007 | 08:48 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
https://www.thirdgen.org/forums/diy-...sation-8d.html
RBob.
Old Mar 15, 2007 | 08:54 AM
ULTM8Z's Avatar
Hey, I even posted in that thread!
(Rbob on the left of course)
Linson
Oct 24, 2025 02:00 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
ULTM8Z
Oct 2, 2015 01:25 PM
IROCZDAVE (88-L98)
Sep 17, 2015 05:46 PM
ULTM8Z
Sep 16, 2015 09:15 AM
