Changing XDF file
Old Mar 19, 2007 | 10:32 AM
Geut's Avatar
Engine: 350TBI
Axle/Gears: 3.42 powertrax
Changing XDF file
Hi,
I was sneaking around in the tunerpro software and came on to the conversion factor of the XDF items.
Am I right when I think that the value I enter in tunerpro, is converted by this factor and writen down the bin ?
Gr.
Dieter
Old Mar 20, 2007 | 05:03 AM
Z69's Avatar
Z69
Yes, TP converts the bin value into a value that means something to you.
For instance the Stoich constant is 445d in the bin.
Which doesn't do anything for you. But TP will make it display as 14.73.
Checkout the help section in TP.
Old Mar 20, 2007 | 09:38 AM
Geut's Avatar
Engine: 350TBI
Thank's.
I have the problem not getting my "EGR Temp On" @ 1B3 above 91.80 .
Can I solve this by changing the conversion factor ?
Or is it just the same,
"91.80 : 0.36 = 255"
and
"150 : 0.588235 = 255"
With 255 being the max value for the ECM, right ?
Am I wrong here ?
Gr.
Dieter
Old Mar 20, 2007 | 11:26 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Changing XDF file
Make the conversion factor a '1', then enter 0 as the temperature value. That will be 151 C for the ECM.
RBob.
Old Mar 20, 2007 | 11:49 AM
Geut's Avatar
Engine: 350TBI
I'll try this.
Gr.
Dieter
tom1985
Apr 19, 2016 07:55 AM
89fast5oh
Sep 27, 2015 09:04 PM
ZZ42Fast
Aug 30, 2015 02:39 PM
tmellott89
Aug 16, 2015 02:58 PM
Omega
Aug 10, 2015 10:24 PM
