closed loop-how much delta fuel?
Old Mar 20, 2007 | 11:22 AM
boatderek's Avatar
does anybody know how much (percentage) change in overall fuel flow the O2 sensor will effect? i am doing an off-road setup (the ocean is way off-road) and i have heard closed loop is only about 2-3% for fine-tuning emissions. i have also heard it will affect fuel flow up to 10 to 15%. thanks.
Old Mar 20, 2007 | 11:55 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: closed loop-how much delta fuel?
More like 20%.
If you are farther than that you have obviously have other problems.
stock movements (on $8D anyway) are around 20 points leaner, 32 points richer adjustment can be made automatically.
That's with 128 being the cetered value.
By changing the bin file you could have additonal magnitude allowed but shouldn't be needed. Will cause problems if the O2 should fail.
Old Mar 21, 2007 | 08:54 PM
Jaxom's Avatar
Car: '89 IROC-Z
Engine: StealthRam 355
Transmission: 6-speed
Axle/Gears: 3.70 9-bolt
The fuel trim feedback system is capable of making enormous changes in the fueling, potentially the 20% JP mentioned and more. A well-tuned engine should never need to adjust more than 5% unless there is a problem or failure.
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
beast94
Aug 20, 2015 06:44 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
