Re SAUJP
Car: 1992 GTA
Engine: running
Transmission: working
Axle/Gears: both
Re SAUJP
Hi all,
Thanks any input or direction is greatly appreciated, later GTA..
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
Re: Re SAUJP
I don't really have any experience on nitrous so i can't speak for any changes to timing there. With my 383 i started by changeing the cyl. volume and injector size. Then i started it up and watched to see where i was. In my case i was a little gassy so i had to pull some fuel out of my lower ve table. Basically just start with the simple stuff and work your way up. I ran with the stock timing tables until i got my ve tables to start ironing out then i started working on my timing unless i had severe knock retard. Hope this helped give you a little information.
Car: 1989 IROC-Z
Engine: 383
Re: Re SAUJP
Theres a formula to figure it out in the stickies up top but mine is set to 784.75
