Limit on recording in TunerPro?
Old Apr 4, 2007 | 12:19 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Maybe there is a configuration setting I missed somewhere, but has anyone else run into a problem where TP quits recording records beyond about 4K records? I've had it do this to me twice in the last 2 days.....
Old Apr 4, 2007 | 05:14 PM
ashman5's Avatar
Car: syclone
Re: Limit on recording in TunerPro?
i regularly record ~20k of data with no problems. never experienced any issue with recordings being shortened or cut off.
Old Apr 5, 2007 | 12:33 AM
vernw's Avatar
Are you saying a 20K data file or 20K records? My problem is 4K number of records (approx 800K of disk space or total data)
Old Apr 5, 2007 | 08:01 AM
ashman5's Avatar
Car: syclone
20K records. my ALDL logs are ~1.5MB in size.
Old Apr 5, 2007 | 08:53 AM
vernw's Avatar
Well, I determined I'm logging all the records too - but they only show up in TP if I export them to a spreadsheet. When doing the log replay inside TP tp see the data on the dashboard, it is recylcing back to the beginning instead of showing any records past about 4091 records. Are you seeing that too?
Old Apr 5, 2007 | 10:55 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I am not completely sure but it may have something to do with the file type? There may be a limit on the total lines available. 800K is a pretty big spreadsheet
Old Apr 5, 2007 | 11:00 AM
vernw's Avatar
The spreadsheet is working fine, it's the playing back the log in TP that seems to be restricted to 4k records....
Old Apr 5, 2007 | 03:55 PM
ashman5's Avatar
Car: syclone
i don't use the playback function. i export everything to spreadsheets.
Old Apr 5, 2007 | 11:21 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
i don't have any problems with the size of my log files. i have some that are up around 3~4 megs.
i seldom ever do a log under about 600k.
on occasion either TP doesn't record or the file gets damaged, that happens maybe 1 out of 50 times.
im not t seeing any settings in TP that would cause your problem.
Ed1LE
Sep 30, 2018 09:14 AM
Mark_ZZ3
May 24, 2018 01:02 PM
gt4373
Oct 8, 2015 10:37 AM
racereese
Oct 3, 2015 03:46 PM
ULTM8Z
Oct 2, 2015 01:25 PM
