PW and Injectors.
Old Apr 11, 2007 | 12:14 AM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Transmission: working
Axle/Gears: both
PW and Injectors.
Hi all,
Old Apr 11, 2007 | 12:20 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: PW and Injectors.
I dont think itll hurt anything, but your close to the static threshold. The worst that will happen will be that the injectors will be static, which will cause the motor to lean out under high loads, which should be avoided. Id plan on bigger ones, especially if you want to enrich the mixture further during WOT.
Old Apr 11, 2007 | 11:06 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Adding fuel only eliminates Knock Retard if you are too lean. Reducing spark (or working the spark curve) is the only effective way to reduce KR, but it may reduce power.
Your DC is fine and your injectors are fine too. You may be able to get more fuel (if really needed) by adding fuel pressure. If you got money to burn and dying to get rid of it, you can buy new (and larger) injectors. Or, you could buy some other part instead that will make a performance difference.
Old Apr 12, 2007 | 12:27 AM
Car: 88 Camaro SC
Engine: SFI'd 350
For reference, you could probably get about 20-25% more flow before the pressure gets so high that you dead-head the pump or put a higher demand then the pump can meet at that pressure rating. If you still have the stock pump, it may or may not be able to meet the demand at higher pressures.
Old Apr 14, 2007 | 04:18 PM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Axle/Gears: both
Thanks, for the reply's
Old Apr 16, 2007 | 12:30 AM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
I've been talking with GTA for a bit.
He's only running about 25* at WOT on a aluminum headed car. (with PE adder, base set correctly and corresponding with the base timing in the chip)
Think it could be a lean issue and not a spark issue?
All cars I see running those heads run 32-38*.
Old Apr 16, 2007 | 02:16 AM
SRPerformance's Avatar
FWIW:
On LS1 engines I have seen 107% Duty Cycle and the car was still not running lean. However, when we changed injectors the car made more peak HP and held the power after that point but up to peak they where lineball. IMHO: I would only change injectors if you are planning more mods and more rpm.
Old Apr 16, 2007 | 02:41 PM
Car: 88 Camaro SC
Engine: SFI'd 350
That does seem a bit low, unless it has a really high CR or something.
It could also be false knock as well.
Old Apr 16, 2007 | 06:58 PM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Axle/Gears: both
Mike ,
Old Apr 16, 2007 | 11:15 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
I did add the 5% Fuel in PE but I will just have to keep playing around This Prom Burning equipment is worth its weight in Gold. GTA
You are welcome
No charge for the equipment as long as you help me with my chip burning
Old Apr 16, 2007 | 11:27 PM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Axle/Gears: both
Help huh?
92-Formula
Dec 12, 2015 10:34 PM
dusterbd
Sep 29, 2015 08:40 AM
BBSDesigns
Sep 22, 2015 03:08 PM
BLK87Z
Sep 18, 2015 11:29 PM
webeeZ28
Sep 14, 2015 12:00 PM
