Need help with datalog please?
Old Apr 12, 2007 | 07:31 AM
8UpAFord's Avatar
Car: 1988 Corvette
Engine: 5.7L TPI L98
Axle/Gears: D36 2:59
i replaced my ECC and know i can datalog. this is GREAT thanks TO everyone. Finally i can figure out what my car needs, and give it what it needs.
Now that i can datalog i really need help understanding a few paramaitors. like inj bpw inj dc and fuel trim. IS there a good sticky, i did a search with not much luck. I need like a all round what to search for when datalogging sticky.
this weekend i did alot of tweeking to my chip and datalogged. I'm a rockie to say the lesast. i just want this thing to run safe no knock and get my blms at 128 then i can focus on AE and PE and maybe timing. Also If there is anything else i'm not seeing. i think my car can def run alot better, smoother,and quicker. right know with my current chip and motor mods. It has slow throttle response and little bog at 1/2 throttle WOT is ok but it can do more i beleve. I know i can't prom beg. it's more like i just need to see what others with more knowlege see that I don't in my data log.
i have list of mods to my motor and chip below. i was wondering if someone could be as so kind to look at my datalog and get me moving in the right direction please???? this is a DATAMASTER file.
Not sure if these really means anythings but i ran the dyno in datamaster and from a 0-60mph run. it graphed out like 200hp and 300tq i know it's not the right way to dyno it. But i'd think it would at least be a little higher then that for a vette?
Motor mods
MAF Descreen & gutted ( might need to adjust my MAF tables)
Air Foil
Milded Porting Plenum/Base/Runners
AFPR 42PSI@wot
Gutted Cats no mufflers (I'm gonna replace with TPIS Full system soon)
Freesbee delete (it's a vibration dampner thats placed over the water pump on Y bodys only)
I think thats it.
Chip Mods
VAT- Disable
EGR-Enable
TCC- Times
Cooling Fans-Times 185-195 *
AC - Loads disable
PE 60% TPS
Everything else stock
File Type: zip
ULTM8Z
Oct 2, 2015 01:25 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
ezobens
Aug 19, 2015 10:29 PM
bamaboy0323
Aug 15, 2015 07:20 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
