engine doesn´t run smooth, gurgling exhaust sound
Old Apr 14, 2007 | 02:44 PM
396V8's Avatar
Car: 1990 Corvette
Engine: 415
Transmission: six speed
Axle/Gears: Dana44 3.73
hi all
i´m running a 396 with SP EFI, 234/238 112LSA .565lift cam...
i managed to tune out idle, WOT is fine...
my problem...when i cruise slowly with low throttle, like 35mph with 3rd or 4th gear with about 2000 rpm, the engine doesnt run smooth, exhaust gets a strange sounding note, with some gurgling, aso
BLM´s are fine...124 to 130
when i get on the throttle, the engine smoothes out...
is this just the nature of the beast, cam surge, or can i do more to minimize this?
thank you
Old Apr 14, 2007 | 08:47 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Re: engine doesn´t run smooth, gurgling exhaust sound
Are you running closed loop? If so, try open loop and richen the mixture a tad.
In closed loop, low rpm & fairly large cams; the "switching" between lean/rich can cause that surging you are mentioning. This is why a number of guys SWEAR by open-loop and tune for the AF ratio they prefer.
In open loop, the ECM doesn't "swing" back & forth between rich & lean and usually runs much smoother.
Old Apr 15, 2007 | 01:29 AM
Steve40th's Avatar
This bin towards the bottom of the page here, http://www.bfranker.badz28.com/LT1Edit/LT1files.htm (Phil Tobins 401) was for a 401 that ran 10's. He had a MUCH bigger cam than you or I do. But he tuned it for closed loop. I dont know if you can read the bin, but it is a DA2.
Old Apr 15, 2007 | 04:21 AM
396V8's Avatar
Car: 1990 Corvette
Engine: 415
Hi
i´m running closed loop, but maybe my 42# injectors are just too big for low cruise condititons..maybe i change them to 30#, but i hope it wont throw off the whole calibration...
at the other hand, i get stable idle with the 42#´s
thank you
Old Apr 15, 2007 | 04:48 AM
396V8's Avatar
Car: 1990 Corvette
Engine: 415
Hi Steve!!
i have read the .bin, looks nothing special...
a few things...
its a 401, but the cylinder volume is set to 713cc´s
injectors look small at 23.4#/hr
volumetric efficiency seems to be low at the whole table...
interesting, isnt it?
Old Apr 15, 2007 | 03:26 PM
Steve40th's Avatar
Intersting it is only for a 5.7 litre and 24# injectors. Maybe this isnt the bin he used in his 401, and it was just his base LT1 when he had a ZZ9 cam.
Frozer!!!
Jan 19, 2024 04:55 PM
db057
Aug 22, 2015 08:17 PM
midias
Aug 22, 2015 01:42 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
