IAT sensor added to 8746.
Old Apr 16, 2007 | 01:03 PM
Ronny's Avatar
need some help guys.
added new sensor. i believe it was from a 1992 Camaro used on my above with EBL. I comfirmed 5V to sensor from the ECU. I confirmed a ground wire (MAP-TPS) functional. nothing at the whats up display? This is before and after I changed table % in my .bin (coolant vs IAT) as well as changed flags. I removed sensor applied some heat car and ohmmeter shows no changes as temps rise. i believe it was said it passes current with no resistance per my friend who is heating/ac tech.
What is test procedure on the sensor?
Old Apr 16, 2007 | 02:55 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: IAT sensor added to 8746.
Ice water and boiling water are the easiest ways if your near sea level. Those provide a 32 degree and 212 degree testpoint. You should get the following resistances with temperature with a DVM (see attached). Boiling water will be ~200 Ohms while ice water will be ~10 kOhms.
Old Apr 16, 2007 | 03:52 PM
Ronny's Avatar
thanks so much.
Old Apr 16, 2007 | 08:56 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
don't mind me...edit
gta892000
Aug 11, 2019 11:16 AM
86White_T/A305
Sep 21, 2015 05:28 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BWilcox
Sep 20, 2015 12:19 PM
BLK87Z
Sep 18, 2015 11:29 PM
