which knock sensor?
Old Apr 19, 2007 | 10:53 AM
CamanoWagon's Avatar
Car: For this site, 91 Caprice wagon
Engine: 350 from an 88 truck
which knock sensor?
I swapped out the POS 305 for a .030 350, with the edelbrock MPFI (still trying to get it to run), and have the stock sensor. What tells me which one to use? Is it soley displacement based? I have a re-pinned 7730 with an AUJP memcal.
More requests to come......
Darryl
Old Apr 19, 2007 | 10:57 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: which knock sensor?
AC...10456549
It's a 350 for the AUJP
Old Apr 19, 2007 | 07:57 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Wagon
Which cam do you have in your 350??? Knock sensors are also tuned for camshafts - roller vs. flat tapet in addition to displacement.
//RF
Old Apr 19, 2007 | 09:15 PM
Binder's Avatar
Is there a spread sheet somewhere that shows the different sensors and their applications?
Old Apr 19, 2007 | 10:13 PM
Flat tappet, very mild RV. I'm reasonably sure the stock one will be fine. I'm not pushing this thing hard, or even setting it up to where detonation will be a real issue. Its going to be the wifes car, when I'm satisfied enough with its reliability and performance.
It would be interesting to see a spreadsheet, though.
Thanks!
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
