autoprom tunerpro won't datalog WOT
Old Apr 26, 2007 | 09:00 PM
survival's Avatar
Car: 1989 Firebird GTA
89 gta,165 6E using tunerpro and autoprom cannot datalog a wot 1/4 mile pass.Can datalog for 1/2 hour around town but the second I go to wide open throttle values are incorrect.Speed incorrect,maf and others are only around half what actually is happening.Any help would be great.
Autoprom settings horizontal switch to the top vertical towards the usb.
thanks
Old Apr 27, 2007 | 02:53 AM
SRPerformance's Avatar
Re: autoprom tunerpro won't datalog WOT
I thought the Autoprom horizontal switch is set away from USB ie pass through mode:
http://www.moates.net/mike/faq.html
specifically: Could tell me how to connect with the APU1/ALDU1 step by step?
Old Apr 28, 2007 | 05:56 PM
survival's Avatar
I'll give it a try.Has anyone else had this problem,I mean why is it ok till you floor it?
Old May 5, 2007 | 01:03 AM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
If it datalogs at all then you've got it set up correctly. I don't have any solid reasons why you'd see the data going strange at WOT, but you might make sure that your setup is solid electically. Perhaps there's some floating ground(s), or a bad ECM? Does it disconnect, or just get erroneous in terms of data output?
Old May 5, 2007 | 03:05 PM
survival's Avatar
Just erroneous data,clean grounds each head plus the block.It only gives half values on playback.Seem to monitor just fine.
Thanks for the reply
Old May 5, 2007 | 05:24 PM
Mangus's Avatar
Transmission: T5WC
Do you have access to another ECM to try?
Old May 5, 2007 | 11:18 PM
survival's Avatar
Yeah I'll give that a try.
Pac J
May 17, 2020 10:44 AM
Mark_ZZ3
May 24, 2018 01:02 PM
tmellott89
Oct 14, 2015 02:06 PM
ULTM8Z
Oct 2, 2015 01:25 PM
Luigytico09
Oct 1, 2015 08:46 AM
