Injector duty cycle, fuel pressure?
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
if i'm thinking correctly 11.81msec @ 5125 rpms are going static correct? i'm running 45psi fuel pressure at WOT should i up it or go bigger injectors, i have 30#'s now.
Re: Injector duty cycle, fuel pressure?
At 5125 RPM you have 11.71mS to complete the injector firing including the bias times, so, yeah, you're way static at 100% dutycycle. You need at least 20% more injector to be safe and that puts you at 36's or you could up your fuel pressure to 65 psi but your pump volume will decrease HTH
Car: 1986 Camaro SC
i'm getting away from the FMU i dont want that high of fuel pressure, i ordered some 42lb injectors
9192camaro
16
Feb 3, 2019 12:21 AM
