how can you tell if your stock prom is bad?
Old May 5, 2007 | 04:49 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
how can you begin to tell if your stock prom is bad or going bad or if its just the ecm etc....
before spending tons of money of sensors where would you buy a new ecm with prom as a stock replacement? or what can you do to test to figure out if either are bad?
Old May 8, 2007 | 05:31 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Re: how can you tell if your stock prom is bad?
Proms/memcals typically don't "go bad". ECMs can though and typcially it's a short of some sort. Bad sensors are by far the most common problem.
A bad prom/memcal typically throw a code 51.
Old May 9, 2007 | 10:18 AM
M1tch's Avatar
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
On WinALDL i was getting an error with my PROM. But recently i found that when i plug anything into the cigarette lighter my ACC fuse shorts which is the door locks, light, hatch open etc. Is that most likely the problem?
Old May 9, 2007 | 10:29 AM
Bobby_80s's Avatar
Axle/Gears: no idea
when i took apart my camaro dash and put it back together my cigerette lighter did the same. just means its shorting out. i took apart the lighter and put it back together wrong, fixed my mistake and no more blown fuses.
but if your havent touched it check the lighter anyway theres a very thin piece of insulation that keeps all 12volts from the battery from getting to the whimpy fuses. if that insulation goes so does your fuse when you push in the lighter. becuase inside it makes contact and shorts out the circuit and blows the fuse.
your prom does not control or have any contact with your door locks, lighter etc... so its not your problem.
if it only happens when you push anything into your cigerrette lighter then your lighter is the problem. either needs to be replaced or taken apart and fixed.
goodluck hope this helps. let us know if it was something else
Steven 86IROC-Z
May 24, 2026 04:52 AM
Glowsock
Jul 24, 2025 03:15 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Sanjay
Aug 12, 2015 03:41 PM
djmarch
Aug 11, 2015 10:22 AM
