First track run AFR good, others lean!!
Old May 7, 2007 | 08:40 PM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
730' ECM.
Went to the track on friday. Having some issues and I have a few questions.
I tuned the AFR with my wideband.
It was OK on the first run then went lean on the others.... I'm not sure if this is tuning related or not? I am running a modified S_aujp bin so BLM's before going into PE won't have an effect.
Why does the AFR vary so much within each RPM tuning range? (3600-4000-4400-4800-5200-5600-6000)
Also - What should WOT KPA be? I'm pulling anywhere from 90.0-93.0kpa at WOT.
Any help would be great.
Thanks.
Run 1: Engine Temp: 93.5*C Air Intake Temp, Start: 66.5*c Finish: 62.7*c
Code:
RPM     AFR  INJ PW
3870	12.4	9.06
3916	12.6	9.09
4045	13.0	9.13
4096	13.0	9.16
4201	12.6	9.16
4255	12.8	9.19
4349	12.6	9.23
4388	12.4	9.17
4509	12.6	9.16
4593	12.8	9.16
4703	12.4	9.14
4749	12.4	9.14
4795	12.2	9.08
4915	12.4	8.94
5041	12.6	8.97
5120	13.0	8.74
5201	13.0	133.56
5229	12.8	8.52
5371	12.4	8.52
5401	12.6	8.47
5461	13.0	8.21
5617	12.6	8.04
5715	13.0	8.04
5782	13.2	7.95
5921	12.6	8.1
5994	12.4	8.01
Run 2: Engine Temp: 95.8*C Air Intake Temp, Start: 69.4*c Finish: 65.5*c
Code:
RPM     AFR     INJ PW
3668	12.8	8.79
3682	13.0	8.94
3766	13.0	8.93
3840	13.0	9.02
3932	13.2	9.06
4012	13.2	9.05
4130	13.0	9.11
4165	13.2	9.11
4274	13.4	9.17
4369	13.2	9.16
4388	13.0	9.09
4509	12.8	9.09
4593	13.0	9.08
4726	13.0	9
4726	12.6	9
4890	13.0	8.9
4915	13.4	8.82
5015	13.4	8.79
5093	13.4	8.68
5173	13.2	8.64
5285	13.2	8.5
5401	13.6	8.29
5461	13.4	8.23
5522	13.4	8.09
5649	13.6	8.03
5748	13.4	8.01
5715	13.8	8.04
6030	13.2	7.95
Run 3: Engine Temp: 95.8*C Air Intake Temp, Start: 68.9*c Finish: 65.5*c
Code:
RPM      AFR    INJ PW
3810	12.6	8.94
3870	13.2	9
3964	13.0	9.05
4012	13.0	9.11
4079	13.0	9.05
4130	12.6	9.17
4183	13.4	9.17
4369	13.2	9.23
4448	12.8	9.17
4530	13.0	9.09
4572	13.0	9.09
4681	12.6	9.03
4749	13.0	9.03
4842	12.8	8.97
4915	13.0	8.79
4964	13.6	8.82
5041	13.4	8.68
5146	13.4	8.61
5229	13.6	8.56
5313	13.4	8.42
5371	13.6	8.29
5461	13.6	8.12
5522	13.6	8.04
5585	14.0	7.97
5682	13.8	7.94
5782	13.8	7.94
5816	13.6	8.01
5886	13.6	7.89
Run 4: Engine Temp: 97.3*C Air Intake Temp, Start: 74.2*c Finish: 70.0*c
Code:
RPM      AFR    INJ PW
3855	13.4	8.9
3870	13.2	8.88
3916	13.0	8.94
3964	13.2	8.96
4096	13.6	8.99
4219	13.6	9.02
4237	13.0	9.08
4330	13.2	9.08
4509	13.2	9.03
4572	12.8	9.06
4659	13.2	9.06
4703	12.8	8.99
4795	12.8	8.85
4890	13.4	8.85
4990	13.2	8.77
4990	13.2	8.67
5067	13.6	8.59
5229	13.8	8.47
5229	13.0	8.42
5342	13.2	8.15
5401	13.8	8.18
5401	13.8	8.12
5585	13.6	8.04
5851	14.0	7.89
Run 5: Engine Temp: 95.0*C Air Intake Temp, Start: 73.7 Finish: 70.0*c
Code:
RPM     AFR    INJ PW
3737	12.6	8.82
3795	13.0	8.88
3870	12.8	8.91
3916	13.4	8.94
3996	13.2	8.94
4130	13.4	8.99
4113	13.2	9.05
4292	13.6	9.05
4292	13.6	9.05
4408	13.4	9.03
4468	13.4	9
4509	12.8	8.97
4703	12.6	9
4749	12.8	8.93
4842	13.2	8.81
4890	13.2	8.81
4964	13.2	8.64
5041	13.4	8.56
5146	13.4	8.42
5201	13.6	8.39
5256	13.2	8.32
5491	13.6	8.35
5431	14.0	8.12
5491	13.8	8.04
5491	13.2	7.9
5553	13.4	7.89
5748	13.0	7.89
5748	13.6	7.89
5682	13.6	7.89
5921	13.6	8.47
5715	12.6	7.94
6068	13.0	7.84
Old May 8, 2007 | 10:58 AM
Z69's Avatar
Z69
Re: First track run AFR good, others lean!!
Stick the PW next to the above data.
The WOT kpa has to be referenced to the barometric pressure.
More than 4 or so kpa difference from key on/engine off map and you might want to customise your CAI some more.
Old May 8, 2007 | 01:32 PM
I updated the first post and added INJ PW.
I also added air intake temps at the starting and finish line.
Looks like key off MAP KPA is 96.5kpa.
WOT kpa at the start of second is 94.5kpa then decays down to 90.6kpa near 6,000rpm.
Thanks.
Old May 8, 2007 | 09:34 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Heat soak is my guess. On the cars I calibrate, I only follow "speed density" in a narrow range near 10-30 degrees C (IAT). Everything else has a multiplier to cancel the effect of IAT on the FUEL (not GM software, btw). It seems that when IAT is ~40C or above, that it doesn't have any measurable effect on my cars. In other words, if IAT is hot enough, the cylinder charge is basically at coolant temperature. This is using a TMAP sensor which has a birdcage IAT sensor built into a MAP sensor that is directly on the manifold, with the birdcage protruding into the flow.
your results may vary.
You may also have a bit of MAP flutter at WOT (too little filtering), if your A/F is jumping so much. The MAP hose can dampen some flutter. Might also be a problem with your wideband.
Old May 8, 2007 | 09:43 PM
Dominic Sorresso's Avatar
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
Was the BLM at 128 or below for these runs?
Old May 8, 2007 | 10:01 PM
RednGold,
I just went out to see if maybe my input into the ECM for the LC-1 is no fuctioning properly.
I directly inputed the LC-1's serial output into my laptop and the results were quite different. The only problem is that I don't get to see the RPM vs AFR just a graph of the AFR.
I did about 5 runs, each pretty close in AFR and the AFR didnt jump up and down like it does when connected through the ECM. First run started at about 90* and the last nearing 100* or more.
My converter flashes to 3000rpm and I did these runs in second.
At 3000rpm is 13.8:1 and decays down to 13.0 near 4700~rpm then up to 14:1 at the shift point - 5900-6,000rpm.
Looks like i've got some adjusting to do.
Dominic,
I tuned BLM's to around the 124 area. They were below 128 on all runs.
Either way, I am running a modified S_aujp bin so BLM's before going into PE won't have an effect. S_aujp removes adjustments of WOT PW due to high BLM's.
Thanks.
specialized
Jun 18, 2022 09:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
89mulletbird
Aug 12, 2015 07:08 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
