can you explain me some tables in $8D
Old May 10, 2007 | 01:57 PM
396V8's Avatar
Car: 1990 Corvette
Engine: 415
Transmission: six speed
Axle/Gears: Dana44 3.73
hi
i would be interested, what this tables are for:
Fast O2 Rich/Lean Treshold vs. MAP
Upper Zero Error Reference for Slow O2 R/L vs. MAP
Lower Zero Error Reference for Slow O2 R/L vs. MAP
and how they can be modified for tuning eg. large cams, aso
Thank you
Old May 10, 2007 | 06:03 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: can you explain me some tables in $8D
Those three tables define the actual AFR when in closed loop. The values are compared against the O2 sensor to move the integrator.
Up in the sticky's, in the Tuning Guide Book, under the '8063/'7747/'8746 ECM section. There is a paper on 747 Fueling. Even though it is a different maskId the principle is the same.
RBob.
Old May 11, 2007 | 10:30 AM
396V8's Avatar
Car: 1990 Corvette
Engine: 415
thank you very much..
this is really an information pool!!
Pac J
May 17, 2020 10:44 AM
Ed1LE
Sep 30, 2018 09:14 AM
antman89iroc
36
Jan 31, 2016 08:42 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
ULTM8Z
Sep 16, 2015 09:15 AM
