Can't upload to Ostrich
Car: 1992 T/A
Engine: 5.7l 355
Transmission: 4L60
Is there a max size .bin that can be uploaded to the Ostrich. For some reason I can't get one to upload and the only difference I can see is that it's bigger then the one that will upload. It's 133kb, is it too big? What am I doing wrong?
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Re: Can't upload to Ostrich
What program are you using to upload to the Ostrich? I am using TunerPro RT for example.
Car: 1992 T/A
Engine: 5.7l 355
Transmission: 4L60
I'm using tunerpro rt as well. I must have done something wrong. I notice all the bin files are 32kb and this particular one is 133kb. I'll have to go over it again and see what I did wrong. This is my first time emulating, trial and error.
Car: check
Engine: check
Transmission: check
Sounds like the file is corrupt or is not the right one. BIN files will be in binary size increments, IE: 16KB, 32KB, 64KB, 128KB, 256KB, no 133 KB.
If this BIN is for your '92 then it will be 32KB, no other size.
RBob.
RBob.
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
If I had to make a SWAG, that's probably one of your datalog files instead of a BIN.
school boy
Oct 22, 2015 11:47 AM
[PA] Stock 91 z28 springs
Orr89RocZ
Sep 13, 2015 09:41 PM
