Idle Question
Old May 21, 2007 | 05:34 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
Idle Question
Had a starter chip burned for my combo by PC and it runs
pretty strong to get started.
Got the Moates APU1 kit to start to learn do it from there
but sent it back to be checked out, as won't connect to
three different computers, probably my screwup
Until I get it back and up and running have a question?
Wanted idle set at about 800 with my cam setup and
wondering if I can adjust in manually, TB set screw without
screwing up off idle responce. Idles at 650 now in closed
loop and wants to load up. Also a problem on braking below 3000 on stall because of the vacumm with low idle.
Realize will have to reajust TPS idle voltage back to specs
after TB set screw adjustment to bring it up to 800.
Any comments or problems as this is temporary until can
get going on chip changes.
Any One???
Old May 23, 2007 | 01:10 PM
jaykar's Avatar
Re: Idle Question
Bump
Old May 26, 2007 | 12:32 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
Re: Idle Question
It is a semi-common practice to do so. Although most, including myself, don't set the commanded idle too far from the actual idle speed. I keep it within 25rpm.
Old May 26, 2007 | 02:40 PM
jaykar's Avatar
Re: Idle Question
Thanks for reply and 25 to 50 rpm idle increase will
help a little until can get my equipment back and learn
to use it.
Need to learn to datalog and start from there
Hope you can't teach a old dog new tricks is just a
fairy tale
Later
MustangBeater20
Oct 29, 2022 09:20 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
