What tables?? Egr-7747
Hey I know that this is an easy question for most of you, but I cannot seem to find the answer in the search forum. I just got my burn1 and Im about to burn my first chip. I have changed my bpc to correct for fuel pressure and set the base timing. What I need to know is what tables or setting's to change to disable the egr. There seems to be alot of them and not sure if I should adjust all of them or just a few. I would assume that you uncheck the flag so it doesnt set the service light?? But what table's do I set so the ecm know's that there is no egr??? Thanks for the help once again!!! Its a 7747 ecm if that helps and Im using $42 xdf, with tunerpro. Greatly appreciate you helping out a newb!!
Car: check
Engine: check
Transmission: check
Re: What tables?? Egr-7747
Just set the EGR enable temperature to the maximum temperature. The ECM will then never enable it.
RBob.
RBob.
86CamaroDan
Sep 29, 2015 10:08 PM
