Rev limit problem however none exist and prom is set to 10k help !!
Old Jun 1, 2007 | 01:52 PM
Destructive099's Avatar
Car: Dark Blue 1987 Chevy Iroc-Z Camaro
Engine: 5.7 350
Axle/Gears: 3:42
Basically the car is running decent from idle-3k however once I hit 3700 rpm she stops as if theirs a rpm limiter, now ive heard rummers theirs rpm limits set in the msd distributer which if their is I cant find it. Ive also questioned myself if I should get a 6al box and maybe that would solve my problem? Just need some input this is driving me nuts b/c everything on the car is basically new and the engine has about 100 miles on her and has yet run good enough to be able to run on the road due to this problem
EDIT: Was just trying to log some data and held it at around 3700 rpms where it sounds as if the rev limit kicks in and seems im having some heat issues when this happens, for the wires had cought on fire at the spark plugs and had to be put out fast ;-) coolant temp by the way was only around 190
Old Jun 1, 2007 | 09:41 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: Rev limit problem however none exist and prom is set to 10k help !!
V6 memcal in a V8 application?
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
perZ
Aug 15, 2015 01:17 PM
gta power
Aug 13, 2015 06:15 AM
