irritating idle
Old Jun 12, 2007 | 09:07 PM
Army Vet's Avatar
Car: 1988 IROC-Z
Engine: 383 TPI
Axle/Gears: 3.73 Posi
irritating idle
Hello, I am having an idle concern I am not sure how to correct. I am using the ARAP .bin with a 6E mask and 165 ecm. I changed the injector constants to 24 lb/hr and the car runs great except at idle. I set the minimum air based on the sticky here. Did it twice and it is dead on. It idles between 800 - 850. It will idle like this for 2 - 3 minutes then the idle jumps to around 1100 for about 2 - 3 seconds then goes back to a nice 800 - 850 idle. When it is idling at 800 - 850 it is real smooth. Here are some values I am getting at idle.
IAC at 0 then goes to 6 then 10 when idle jumps, then goes back to 0
BLM at cell 0 then goes to cell 1 when idle jumps
BLM at idle 135 - 143 in cell 0, goes to 128 when idle jumps and BLM goes to cell 1
Int always between 121 - 128 even when BLM is in cell 0
No fault codes, no other erratic values noticed. MAF in good condition. Other than this concern car runs like a raped ape, BLM and INT are good throughout the power band. I am using tuner pro rt. Hope someone can help. Thanks.
Old Jun 12, 2007 | 09:34 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Re: irritating idle
My only guess right now is a TPS problem. Move the TPS only (loosen the screws), and twist it until the TPS volts are about .54V.
I think you might be right on the edge of "open" and "closed" for the TPS voltage, and it's sometimes triggering throttle follower.
Old Jun 12, 2007 | 09:43 PM
Army Vet's Avatar
Car: 1988 IROC-Z
Engine: 383 TPI
Re: irritating idle
TPS is holding solid at .54 volts. I adjusted this when I did the minimum air speed. I have been checking and double checking everything I can for the past few days. I am thinking I need to change something in teh .bin but am not sure what. Thanks.
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
