Tuning 7749 Ecm
Old Jun 18, 2007 | 09:01 PM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Tuning 7749 Ecm
I finally had a light bulb turn on today and was able to get my 7749 ecm running. I hadn't any idea that the VE tables were a little different. I found that the F31E (Closed Throttle) must be tuned in 1st. Then the F29 table which is VE above 0% throttle. I have to thank RED~N~GOLD and Grumpy for their knowledge. I should be almost ready tomorrow night to fine tune. One problem that I am still having is acceleration popping.
I am running a sbc 355 with 38# injectors and a TPIS Miniram. I know the miniram likes it fuel so I am guessing that I need to pump up the fuel in an AE table. I was told before that the F22 (AE Delta throttle contrib ~VS~ Delta TPS all tables should be put to 300 otherwise you will encounter a rich bog under acceleration. Does anyone have any ideas??
Old Jun 18, 2007 | 09:56 PM
Z69's Avatar
Z69
Re: Tuning 7749 Ecm
8D MR tunes have the AE increased about 1.5 to 2.0 above stock.
But that is usually with 24's or 30's.
I've never looked into the $58 AE tables.
Old Jun 20, 2007 | 05:37 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Re: Tuning 7749 Ecm
Mine is around 100 now, only tuned N/A so far this year, I use to increase it some when I tune for boost applic.
/N.
Old Jun 22, 2007 | 07:56 AM
ibmtech's Avatar
Car: 1987 IROC-Z
Re: Tuning 7749 Ecm
My current configuration with the car would definetely be above stock config. I did find some useful info on http://www.syty.net/forums/showthread.php?t=36086 but they still do not address this issue correctly. The next problem I am getting is I have to actually start the car almost 5 times before it stays running and runs good. I know the tables in the $58 are around the F50 - F59 range. I just haven't figured that one out as of yet. Tuning of the 7730 ecm so much easier.
Old Jun 23, 2007 | 08:29 AM
ibmtech's Avatar
Car: 1987 IROC-Z
Re: Tuning 7749 Ecm
I don't know what happened last night but everything started to work right. At least I know the INT & BLM's came right togethor around 128. Getting some strange knock counts on the 749 that wasn't on the 730 ecm though. I removed the adapter that I made for the 749 and put the 730 ecm back in. Plugged in the 1 bar map and restarted the engine. I wasn't able to get any knock counts. I tried everything and got around 10 or 11.. I get 405 right off the bat as soon as I start the car when the 749 is plugged in. Any ideas???
F.I. 57 Belair
Aug 23, 2021 01:09 AM
skeltor
Feb 2, 2016 10:37 AM
customblackbird
Oct 1, 2015 04:30 PM
aharvel50
Sep 21, 2015 07:31 PM
eustodp
Sep 20, 2015 05:09 PM
