disassembling a `727 ECM- anybody done already?
Old Jun 24, 2007 | 10:39 AM
396V8's Avatar
Car: 1990 Corvette
Engine: 415
Transmission: six speed
Axle/Gears: Dana44 3.73
hi all
maybe you remember my thread about whacky contacts in my ECM (when changing chips, eg)
so, have anybody of you disassmebled such a ECM?
i took a closer look today, it seems, that there are some rivets, that have to be drilled out..?
i have a spare ECM liing around, so i think, i will do this experiment...
opinions are welcome!!
thank you
Old Jun 24, 2007 | 12:30 PM
MonteCarSlow's Avatar
Car: 1988 Monte Carlo SS
Engine: 5.7L TPI
Re: disassembling a `727 ECM- anybody done already?
I think there are 8 screws that need to come out. Then you might have to fight with the end seal a little bit before it slides out of the case.
Old Jun 24, 2007 | 03:28 PM
396V8's Avatar
Car: 1990 Corvette
Engine: 415
hi
yes, there are 8 screws, i pulled them, and tried to pry carefully the end seal open..
but, when you look inside the case, it seems, that the inner case, where the curcuit board is held, is riveted from outside..
anyways, i will give it another try, and see what happens..
i have the problem with my ECM, when i insert a new chip, i get SYS in the Display, come from a MEMCAL failure..then, i whiggle around a bit, and it is ok..
i swapped chip adapters, same thing
so, the culprit must be a loose pin in the ECM...
other opinions?
thank you
TraviZ
May 10, 2009 04:24 PM
EdgesZ28
Nov 20, 2006 05:02 PM
FrozenFirebird
Mar 24, 2004 03:13 AM
Matt87GTA
Mar 26, 2003 03:15 PM
