XDF files??
Old Jun 25, 2007 | 12:19 PM
90c350's Avatar
XDF files??
Hey all im just wondering if anyone can tell me wether or not the $42 xdf file off of moates site is still accurate?? I have two versions and not sure which one is right?? The one from moates only seems to display 3 flags/switches in that table, is that right?? The other version I have seems to have alot more flags/switches in it. The one from moates seems to have more options for constants and table than the other one that I have??? I cant remember where the one that is not from moates site came from but it is different. Can anyone direct me to the right $42 XDF file or clear up some confusion please?? Thanks again. Sorry a little new at this
Old Jun 25, 2007 | 02:54 PM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Re: XDF files??
If you goto tunerpro.net and look for the 7747mine.ecu file from there. You can import that into your tuner pro. That is what I had to use for a friend. I have attached the one from Tunerpro.net. All you have to do is change the file extension from 7747mine.txt to 7747mine.ecu and you it should be ready to use. Yes, The one from Moates.net only does have 3. I don't understand that one either.
File Type: txt
Old Jun 25, 2007 | 04:36 PM
90c350's Avatar
Re: XDF files??
Hey thanks for the info!! I just wanted to make sure that it wasnt just me LOL
Old Jun 26, 2007 | 09:22 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Re: XDF files??
The definition files are mostly user-created. One being different from another does not necessarily mean that it is wrong. Some people define more things, some people define less. Some people call the item by different names, etc.
You can very likely use either definition you found.
Old Jun 26, 2007 | 09:30 PM
ibmtech's Avatar
Car: 1987 IROC-Z
Re: XDF files??
Thanks for the info on that. I have never seen one that short before. I now know..LOL
InfernalVortex
Apr 20, 2021 11:31 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
Jonas Earl
Sep 27, 2015 07:39 AM
MitcherNeaf
Sep 24, 2015 09:23 PM
80smetalfan
Sep 22, 2015 02:55 PM
