APU1 AutoProm
Car: 1988 firbird formula
Engine: 5.7l pony eater
Axle/Gears: 4.10
APU1 AutoProm
did a search with no results,
is anyone using his setup? i would like RT tuning capibilities, is this any better than ostrich other than the APU1 is in stock and cost more?
Car: 1987 Corvette
Engine: 383 ci
Transmission: ZF 6 Speed
Axle/Gears: 4.10 Dana 44
Re: APU1 AutoProm
I use the AutoProm and love it. Check out http://moates.net/ and read about the functions of it vs the Ostrich. You can do a heck of a lot with it.
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Re: APU1 AutoProm
The emulation portion of the APU1 is basically identical to the Ostrich, so you can go either way there. The APU1 also includes an ALDL interface and a chip burner. The Ostrich, however, is just an emulator (you'll need an external ALDL interface if you choose to go that route).
The AutoProm is an "all in one" package. Tuning with the Ostrich typically requires a few other components.
For either the Ostrich or the AutoProm, you'll need a chip adapter for your ECM (G1 or G2 depending on your ECM).
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: APU1 AutoProm
i have the AutoProm & i love, it does everything i expected it to do, coming with TunerPro was icing on the cake.
if you already have a chip burner & can data log, the Ostrich is probably the way to go, if you don't have a burner, then the AutoProm is the way to go.
Car: 86 Camaro Iroc-Z
Engine: 305ci TPI
Re: APU1 AutoProm
hmm the search must have been broke if there were no results..
I recently bought the Autoprom USB and it is very nice.
APU1 = Ostrich + chip burner/reader + ALDL cable
both ostrich and autoprom will let you do realtime changes im almost certain
UltRoadWarrior9
Apr 28, 2020 10:39 PM
