Tuning Problem (HELP!!)
Old Jul 3, 2007 | 12:01 PM
TheBadazz's Avatar
Car: Pontiac T/A
Axle/Gears: Borg Warner 9-Bolt w/ 2.77 gears.
I'm trying to tune my 92 RS with the TunerProRT Program. My computer is linked to my Romulator........but the romulator isn't uploading the info into my ECM. I've changed my fuel pulses to zero. No change! Car still running (but it shouldn't). (car not in limp home mode) I've tried so much that I'm going crazy. Please can anyone help. Thanks in advance.
Old Jul 4, 2007 | 11:35 AM
TheBadazz's Avatar
Car: Pontiac T/A
Re: Tuning Problem (HELP!!)
Can some please help. Thank you.
Old Jul 4, 2007 | 12:05 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I use an Ostrich, not a Romulator, but on the Ostrich I have to change some jumper settings to make it work with the TBI computer. Did you do that on the Romulator? How do you have the Romulator hooked up to your car's ECM? Please describe in details so we can try to help.
Old Jul 5, 2007 | 03:41 PM
TheBadazz's Avatar
Car: Pontiac T/A
I guess we are talking about the same thing (Ostrich/Romulator). It's a Moates product. The Rom is connected by removing the chip and using the supplied strip that was hooked up and installed by John at Custom EFIS.
As far as the Laptop to Rom connection that's fine. It's when we try to make changes to the tune the ECM is not getting the info from the ROM. It's not in Limp home mode either. Right now the only way the car will run good enough to idle on its own is thruogh a mail order chip burned by John who tested the Rom and ECM on his own car. Thanks for any info you have on this.
Street Lethal
Apr 30, 2019 12:14 PM
nuggie
Aug 25, 2015 01:27 PM
soarestransam
Aug 24, 2015 08:15 AM
ezobens
Aug 19, 2015 10:29 PM
zeitghaist
Aug 18, 2015 07:33 AM
