Zeitronix ZT-2 hookup
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I'm trying to hook this up to my NA vin 8 730 ECM.
This is where i'm at so far:
ZT - red > bat fuse block (this is switched 12 not on while cranking)
ZT - orange > ECM pin F15 (MAP input)
ZT - black > ECM pin A12 (ground)
ZT - grey > ECM pin F13 (TPS input)
My questions are:
Where does ZT white (WB analog output) go?
Where does ZT green (tach signal) go? pin D9?
Where does ZT white/blue (warning output) go?
Where does ZT brown (sensor ground EMS) go? A sensor ground?
Where does ZT purple (simulated nb O2 output) go?
Where does ZT brown (sensor ground (boost sensor ground reference)) go?
Where does ZT blue (user input 0-5v) go?
Lots of questions I know but the install instructions don't explain much. Not much of it matches up with my service manual either. The google search leaves much to be desired as well.
Some of these wires I don't believe I need.
Any and all help will be greatly appreciated. My intentions are to get this hooked up into the datastream. I plan on using the WB at all times.
My questions are:
Car: superrammed V
Engine: 396 SBC Speed Density
Axle/Gears: Dana44 3.45
Re: Zeitronix ZT-2 hookup
Same questions here..
I have somewhere some documentation for my vette installing the ZT2 (not yet installed..)
..Courious to know what " sensor ground EMS " means...
EMS it's for?
EMS it's for?
Car: 92 GTA/ 00 TA
Engine: 383/350
My guess is Engine Management System.
Car: 92 GTA/ 00 TA
Engine: 383/350
I'm going to assume that several of these wires aren't used in my application.
In the meantime, i've disabled closed loop.
Help?
Help?
Brian Shaughnessy
May 30, 2001 06:10 AM
