Would elec fan affect A/F ratio that much?
Old Jul 17, 2007 | 08:30 AM
silvernblack's Avatar
Engine: RamJet 350 running EZ-EFI 2.0
Transmission: Richmond 6-speed
Axle/Gears: 4.1
Greetings, I'm running a RAmJet 350 with a 730 ECM. Yesterday I finished installing an electric fan...which replace a mechanical fan which did NOT have a clutch.
My a/f ratio appears to have changed quite a bit...does that make sense? It appears that I'm going to have to start all over on my tuning now...if that is the case.
Old Jul 17, 2007 | 08:53 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Re: Would elec fan affect A/F ratio that much?
Going from the mech to electric fan shouldnt make a huge impact, from the couple I have done.(meaning tune would be fine either way, might notice a little bit of change and that would be all)
However doing one that had a vehicle with marginal electrical system and it was much more apparent.
MAke sure the wiring and alternator are up to snuff and then work from there before u waste time chasing your tail.
If it had a heavy duty clutch or the orig GM(in 100% working) order, u would see a bigger diff as well.
later
Jeremy
Old Jul 17, 2007 | 09:54 AM
Axle/Gears: 4.1
I buffed up the electrical system first. I've got a CS-144 and it maintains voltage just super...I'm quite impressed with it, since I had a 94 amp 12SI before.
I need to figure out my TPS voltage....I'm having problems getting my TunerproRT to connect with the ALDL so I can't get a reading on the computer..I'm pretty sure it's way off now. Any idea how to get a reading off the TPS with digital multimeter? If anyone has an acceptable range of values that would be great also.
InfernalVortex
Apr 20, 2021 11:31 AM
sheachopper
Jul 31, 2019 11:27 AM
Fanatic1074
Oct 2, 2015 03:47 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
