Help finding a bin
Old Jul 17, 2007 | 09:29 AM
TheBadazz's Avatar
Car: Pontiac T/A
Axle/Gears: Borg Warner 9-Bolt w/ 2.77 gears.
Help finding a bin
I need some help finding a bin close enough to my engine ..... so I can start tuning it with TunerPro. Right now it's running too lean (16-18 AFR). Here's my 1992 Camaro RS package.........355ci750 TBI with multi-port conversion (8) 35lb hr injectors...Single Plane multi-port intake maniflod....Sportman II ported heads (200 cc)....212/218 cam @ .050 with LSA 110 (retarded -6 on the cam)....1.6 roller rockers....1 5/8 headers with a Dynomax Race Cat-back (no cat).....3200 stall converter with a 3.42 rear gear....Adjustable fuel presurre Reg.....8746 ECM with Ostrich.......If there is anyone here that can point me toward a bin for that package..... it would be really helpful. Thank you.
Old Jul 17, 2007 | 11:20 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Help finding a bin
You won't find any stock BIN close to your engine combo. Best bet is to use the stock BIN that came in your ECM/vehicle and start with that.
Set the BPC, reduce the MAP AE too almost nothing, reduce the TPS AE a bunch. Then see how it runs and go from there.
RBob.
Hotrodboba400
Dec 10, 2019 07:07 PM
383cam
Sep 9, 2015 06:01 AM
IROCZ1989
Sep 4, 2015 11:54 AM
85Special
Sep 3, 2015 04:21 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
