'747 fun stuff
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
'747 fun stuff
I have an '84 GMC 1/2 ton with a TH350. I also have an engine, harness, ecm, and other things from an '87 thats TBI. I'm thinking of putting the TBI setup on the '84.
I'm not sure if I can pull off the VSS though. It's cable driven to the dash. I have not pulled out the dash yet, nor do I have a wiring diagram but I don't know if it has a buffered VSS output wire to the ECM like on the '87+ trucks/cars.
Assuming I can't get a reliable VSS to the ECM, how do you feel about disabling the VSS in the bin?
I'm not too familiar with the TBI code, does it have different fuel modes based on VSS ?
-- Joe
-- Joe
Car: 1983 G20 Chevy
Transmission: 4L60
Re: '747 fun stuff
-- Joe
-- Joe
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Re: '747 fun stuff
As long as the truck had the CC quadrajet it will have a VSS. There's an optical sensor on the back of the speedo, should still be a yellow buffer box to pull your vss from. I did this with my 84 monte.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: '747 fun stuff
I'm trying to locate a wiring schematic. There is a connector that goes to the dash, I figure it's ECM power, vss, but what else. hrmm.
-- Joe
LT1Formula
Oct 8, 2015 08:34 PM
