I'm going to start over with AXCN
Old Jul 20, 2007 | 10:11 AM
silvernblack's Avatar
Engine: RamJet 350 running EZ-EFI 2.0
Transmission: Richmond 6-speed
Axle/Gears: 4.1
I'm running a RamJet 350 with a 730 ECM. I haven't been able to get the idle to work properly. Runs quite well everywhere else, and the BLMs are fairly good above idle also. Anyway, I'm going to start over since I have a pretty good bin for everywhere buy idle.
I need a little guidance on the initial mechanical settings since the RamJet values are a little goofy as shown below:
TP Sensor 0.70-0.80 volts with Idle Air Control at 20-40 counts.
The 20-40 counts sounds ok, but that TPS voltage seems a bit high. What would be a sat value to TPS voltage?
I'm going to set the timing to 6 degrees (per the AXCN Bin) and start there.
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
