1227727 ECM help
Old Jul 21, 2007 | 06:22 AM
396V8's Avatar
Car: 1990 Corvette
Engine: 415
Transmission: six speed
Axle/Gears: Dana44 3.73
1227727 ECM help
hi
i found this ECM : http://cgi.ebay.com/ebaymotors/12277...QQcmdZViewItem
is this the "common" 1227727 ECM, oder something special?
thank you
Old Jul 22, 2007 | 02:26 PM
396V8's Avatar
Car: 1990 Corvette
Engine: 415
Re: 1227727 ECM help
no one ? :-(
Old Jul 22, 2007 | 05:57 PM
71403's Avatar
Engine: X
Transmission: MT1
That one is the same as the millions of other 727's out there.
Don't see where it says anything "special" about it.
Old Jul 23, 2007 | 01:39 PM
s24a's Avatar
The only thing "special" about it is that it looks to contain a 2.8/3.1 V6 MEMCAL.
Which isn't much use if you want limp-home in a V8!
Old Jul 23, 2007 | 01:46 PM
396V8's Avatar
Car: 1990 Corvette
Engine: 415
hi
since my car is heavily modded, it wont run on limp-home-mode...
ok, another think...when i modify the MEMCAL with a ZIF socket, and everything function properly, will the V6 limp-home network have an influence? or will this become only active, when theres a chip failure? e.g. chip not correct, sth..
if this works, this would be a nice alternative to the known piggyback adapters...
would be interesting....
thank you
Old Jul 23, 2007 | 02:27 PM
s24a's Avatar
Originally Posted by 396V8
hi
thank you
You should get a complete MEMCAL for a V8.
The MEMCAL contains the following:
o EPROM for SW and calibration (27C128 or 27C256 depending on code you run as "base" - eg: stock configuration, no emulation or expander/multical memory IC)
o Resistor NETRES ICs (2) that run spark and fueling if the EPROM fails
o Knock Thickfilm assembly for EST control with knock sensor
A V6 MEMCAL ha these items as well, BUT, they are NOT configured for a V8.
In fact, the MEMCALs for a 5.0L TPI are different than a 5.7L due to the Knock Thickfilm assembly (frequency tuning of the knock sensor)
So my recommendation is to go to GMPARTSDIRECT and buy a correct base V8 MEMCAL for your application, and then remove the EPROM and socket it for the emulator or for replaceable EPROMs.
BTW....If its NOT a SBC, then pick your V8 MEMCAL based on closest bore size of your engine.....
Old Jul 23, 2007 | 02:32 PM
396V8's Avatar
Car: 1990 Corvette
Engine: 415
wow..thats great information
thank you very much!!! :-)
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
