which pins on 7730 need to be hot all the time for the memory?
Old Jul 25, 2007 | 10:53 PM
383LT1intake's Avatar
Car: 92 camaro
Engine: 383 stroker
Transmission: probuilt 700r4
I jus put the 7730 in my car and need to know which pins need to be hot all the time i think i loose my ecm memory after i turn my car off my blm's are always 128 after i start my car and i know they were lower when i turned it off so i think my ecm is relearning everytime i restart i think i have
b1 and b16 " going to battery thanks
Old Jul 26, 2007 | 08:56 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Re: which pins on 7730 need to be hot all the time for the memory?
I don't have the diagram in front of me but I swear the 165 wire and the 730wires were both orange in color?
Old Jul 26, 2007 | 09:05 AM
s24a's Avatar
My Schematics show B1 and C16 as Battery inputs.
Attached is a PDF of a wiring schematic that I have used for conversions between 730, 727 and 749 ECMs.
(and yes, I know the IAC lines do change based on SW mask). This does work for me, though.
File Type: pdf
Old Jul 26, 2007 | 10:13 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The $8D code only saves two of the cells. And only if the engine temperature is within a certain range.
The hac lists the limits and what cells are saved and such as the 'SAM Cells.'
RBob.
Old Jul 26, 2007 | 01:58 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Also - remember - when you FIRST start it up it will be in open loop and by definition the BLMs are 128 then.
{edit in error, added post reply as an edit by mistake. Sorry vernw. Text is as was originally posted. RBob}
Old Jul 26, 2007 | 05:02 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
: $8D code : Actually, this isn't entirely true. If the one or two of the SAM cells are saved, they will be used from startup. The others will be set to 128. There are also limits for the SAM cells. At key-on init they are checked to be within a window. If not, the cell value will be set to the edge value of the window.
RBob.
eightsixseven
Dec 16, 2024 01:50 PM
89GTAOz
May 16, 2020 09:31 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
ZsTransAm
Aug 11, 2015 07:30 PM
bryan623
Aug 10, 2015 11:33 AM
