Can't put tunerpro or winaldl on laptop
Old Aug 5, 2007 | 06:41 PM
icarus402001's Avatar
I downloaded both programs to a floppy but when I try to install them on my laptop it says it can't read tunerpro and do not read winaldl, What am I doing wrong?! The laptop is an IBM 760XL with win98. Both programs show up on the floppy when I check with my PC.
Old Aug 5, 2007 | 11:26 PM
90c350's Avatar
Re: Can't put tunerpro or winaldl on laptop
Do you have a usb port on your laptop??? If so i ran into the same problem with mine. I had to use a flash card or memory stick to transfer winaldl over. It was alot simpler etc. You Could also make your life alot easier and just hook the laptop up to the net for five minutes and download directly!! Hope this helps
Old Aug 6, 2007 | 05:10 AM
I thought of both but there's no USB on my laptop and I need to find a modem.
Old Aug 6, 2007 | 12:51 PM
90c350's Avatar
I would recommend getting a usb card for it!! I had only one usb port on mine so I got a usb card for it and it makes things alot easier. You will Probably need a usb port in order to datalog any way. I think they are normally about $25 or so.
Azrael91966669
25
Jun 20, 2017 04:04 AM
89fast5oh
Sep 27, 2015 09:04 PM
CORV3TT3
Aug 23, 2015 11:26 AM
beast94
Aug 20, 2015 06:44 AM
tmellott89
Aug 16, 2015 02:58 PM
