6E displacement location in cal
Car: '89 IROC-Z
Engine: StealthRam 355
Transmission: 6-speed
Axle/Gears: 3.70 9-bolt
I'm converting a friend's '85 LB9 to '89 code to eliminate the CSI and MAF control module. The physical work took all of two hours, but I've run into a slight snag. $6E is the only code I know to use, and the copy I have is virgin from an L98 car. The .xdf I'm using has no option to adjust for displacement that I can see. Does anyone have/know of a more complete def I can download, or know the memory location and conversion so I can add a displacement adjustment to my .xdf? Any help would be greatly appreciated.
Car: check
Engine: check
Transmission: check
Re: 6E displacement location in cal
There isn't a displacement constant in the code. The airflow from the MAF takes care of it. There is an injector constant though.
RBob.
RBob.
Car: '89 IROC-Z
Well don't I feel stupid....
This is only my second time playing with MAF code....both of mine are $8D.
Thanks RBob!!
Thanks RBob!!
efiguy
Sep 27, 2015 01:30 PM
