Need help adding Extended Upper VE table to Tunercat TDF
Old Aug 7, 2007 | 09:10 PM
Desert86Roc's Avatar
I am not sure I added the table correctly. The values look way out of range. Before I go changing anything, I want to be sure I am in the right area. I am using the S_AUJP_V3 bin file (not the s_aujp_v3), and the values shown are:
I followed the information at the end of the V3 text file, but maybe I missed a value or a scaling factor?
Extended VE info:
/*startAddr =1003,
/*columns =9,
/*rows =13,
/*elementSize =1,
/*bitMask =0,
/*offset =0.000000,
/*mulOrDivOrBit =0,
/*factor =0.390625,
/*map_name =Volumetric Efficency Upper Table Extended to 6400 RPM,
/*ylabel =RPM,
/*yaxis = 1600 2000 2400 2800 3200 3600 4000 4400 4800 5200 5600 6000 6400 6800,
/*xlabel =MAP (kPa),
/*xaxis =20 30 40 50 60 70 80 90 100,,
Here is the TDF Editor screen:
Old Aug 8, 2007 | 08:37 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Need help adding Extended Upper VE table to Tunercat TDF
In the TDF editor, the 'Conversion Factors' group box, the 'Scale Factor' entry, place this value in it: 0.390625
That should do it.
RBob.
Old Aug 8, 2007 | 01:33 PM
Thanks! I saw the "factor" line, but there were conversion, bias and scalar factor options on that screen and didnt know where to put it.
sheachopper
Jul 31, 2019 11:27 AM
Ed1LE
Sep 30, 2018 09:14 AM
KCG
Mid-Atlantic Region
Oct 25, 2015 06:57 AM
gord327
Oct 3, 2015 01:25 PM
ULTM8Z
Oct 2, 2015 01:25 PM
