AutoMeter 2246
Old Aug 13, 2007 | 01:55 PM
chevyz71man's Avatar
AutoMeter 2246
Well I just picked up a 0-100psi fuel pressure transducer from the local speed shop. Then stopped at the local scrap yard and grabbed a late model TPS connector to plug into it. Now does anybody have any idea which wire goes were? Do I give it 5+ volt signal or 12+ volt?? The guage is another like 100 bucks, forget that business. Any info on it would be great!! Need to get that fuel pressure up, my DC is 95% around 4200rpm.. And to top it off my holley TB is toast, The shaft bearings are shot and it drips a tiny bit of fuel out. I am on the hunt for a 454 unit now.
Old Aug 13, 2007 | 02:48 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: AutoMeter 2246
'71man
The sensor that you pickup up at the speed shop was probably made by Kavlico and operates of +5 Volt rail (0.5 to 4.5 Vdc), model P155. Take a close look at the data sheet and compare against your unit...
I hope this helps.
//RF
File Type: pdf
Old Aug 13, 2007 | 02:51 PM
Re: AutoMeter 2246
that is exactly what I needed. Thanks!!
Hotrodboba400
Dec 10, 2019 07:07 PM
90formulaVortec
Sep 8, 2015 12:42 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
gta324
Aftermarket Product Review
Nov 21, 2000 07:52 PM
