Data logging problem
Old Aug 13, 2007 | 07:59 PM
vbMike's Avatar
Car: 1987 Camaro IROC-Z28
Engine: TPI 350ci L98
Transmission: T56 - Hurst Shifter
Axle/Gears: BW - 3.70
I’m having this weird problem data logging that has never happened before. I connect and start logging the data, after about 30 seconds the communication stops for about 5 – 10 seconds and then resumes. I just purchased a prominator and I wanted to download my bin file before I installed the prominator. When I try to download the bin it will freeze and then time out and give me an error saying that communication with the car had been lost. I am using the Moates GMECM software. I know it’s an old Dos program but it’s always worked for me. Are there any other programs I can use to download my bin? I have a 165 ecm and $32B code. Has anyone seen this problem before?
What is the baud rate supposed to be set at? I was using 8192 which I believe is correct.
When I was connecting the 10k ohm resistor tonight to get into ALDL mode I couldn’t remember which pins to jumper and I may have jumped pins G & H for a second or two. I’m not sure what these pins do but would this have caused a problem?
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
Amillionoh7
Sep 5, 2015 11:44 PM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
