Will the PP2 program a socketed LT1 ECM?
Old Aug 14, 2007 | 05:15 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
A friend of mine just had his 94 LT1 ECM socketed and asked me if I can program his flash chips on my PP2.
Old Aug 17, 2007 | 03:55 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: Will the PP2 program a socketed LT1 ECM?
What did he replace them with? It might. Check xtronics.com for the suppported chips, or within the programmer software itself.
Old Aug 18, 2007 | 02:01 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
If he's using 29C256 or 29C512 chips then most definitely you can.
Old Aug 18, 2007 | 09:17 PM
11sORbust's Avatar
Yes....I used one awhile back...
....some more LT1 programming info...
https://www.thirdgen.org/forums/diy-...-flashing.html
Old Aug 18, 2007 | 11:45 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Some people go with the Intel chip and some go with the Atmel chip. Overall, if you have a PLCC adapter then you can do it. It has been a while but I thought the entire bin was 128K and the ECM put the proper 64K into the right chip. Do you know how to break up the 128K bin for eack 64K chip?
Old Aug 26, 2007 | 09:48 PM
11sORbust's Avatar
Nope, I just have the 128k file from tunercat. Plus the t/e side 64k raw dumps. Guess it's possible to look at the start of the 128k file and compare it to the start of both 64k files. I'm not good at assembly but could recognise that. The first part might have bootloader, that is what I'm interested in.
Really, I think a 5v flash chip could work. The circut board will supply 12 volts. If it doesn't blow the chip out, all should be fine. I have seen several devices actually run better with more voltage (and never get damaged).
Old Aug 27, 2007 | 11:46 PM
JPrevost's Avatar
Car: 91 Red Sled
Yes but you'll need an adapter from xtronics.
Fronzizzle
Feb 9, 2017 09:31 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
ramicio
Sep 28, 2015 01:18 PM
L0tuS
Sep 4, 2015 11:16 PM
