DA2 LT1 Speed density. Running lean in WOT how to richen with Tuner Cat?
Old Aug 25, 2007 | 09:56 PM
Steve40th's Avatar
I have a 93 LT1 where it is running lean at wot from 3000rpm to 5500rpm. I have tunercat, a LM1 wideband and TTS datamaster to log, adjust etc etc, and a Moates Burn1 to burn my chips.
But, how much do I adjust the "% change to fuel/air ratio vs rpm at wot" to get the AFR to richen up .1 % -1 full point as it is going from 13.1 to 14!!!
Old Aug 26, 2007 | 02:12 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: DA2 LT1 Speed density. Running lean in WOT how to richen with Tuner Cat?
What are the current multipliers? If the multipliers along with the desired base AFR give you the AFR you want but your going lean, then its some other issue, such as maybe the VEs are off or there is a fuel delivery problem.
Old Aug 26, 2007 | 03:32 PM
Steve40th's Avatar
Thanks, I am going to start from scratch. New fuel filter, correct fuel pressure. Drive and adjust till the VE table, speed density, are as good as possible, so when it does go into PE enrichment for WOT, it wont adjust due to BLMs being off.
Old Aug 26, 2007 | 09:40 PM
11sORbust's Avatar
You need to read up on the sticky topics. Much of the TPI computer logic applies to LT1's.
Old Aug 27, 2007 | 01:40 AM
Steve40th's Avatar
Yep, been there. Very time consuming and confusing. Lots of time needed to do trial and error. Over time it will become easy, but there is so much information it becomes too much.
I am doing one step at a time. I will start from the beginning like I said. I did today. A couple of WOT runs and the car is running better at WOT. My fuel pressure was up 4 psi from the 43.5 factory setting, so this may have helped the way it ran. I dont drive it very often, so I need to drive it more, collect more data and fine tune VE tables, then worry about WOT. Idle is very good now, and it idles at 14.2-14.4 AFR, at a steady 825rpm. No hiccups, no hesitation, just smooth. Just want to get the Ve's good so the PE mode is not screwing with the AFR at WOT.
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
