F-body prom work for 90 suburban?
Car: 85 Camaro
Engine: Cadillac 500
Transmission: TH400
Axle/Gears: 9 bolt
i recently purchased a 90 suburban with a tbi 350 700r4 and 4x4. i was wondering if i can use the same programs you guys are using to help take advantage of the new parts i have for it ( headers exhaust t.b. spacer k&n filter)
thanks
Kevin R.
thanks
Kevin R.
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Re: F-body prom work for 90 suburban?
You can burn your own chips for the burb just like you would for a F body. Just need the bin. file and xdf to get started.
Car: 1983 G20 Chevy
Transmission: 4L60
That should be the 1227747 ECM, probably has the ASCU calibration. You can use the same hardware/software that the TBI guys use. That is where I started. Just get the appropriate definitions and calibrations.
Car: Death Mobile
Engine: 666 c.i.
Also, while you may find the "free stuff" may be a limited (I am not entirely familiar with your specific setup) - there are "bin editor" programs like Tunercat www.tunercat.com that definitely cover your equipment.
Also, you are welcome to post here and ask questions. Many of the "tuning posts" are generic and useful for tuning ALL ECMs. You can ask specific questions that are unique to your vehicle and hopefully someone can help you.
But do remember that this is a 3rd Gen F-body site so sometimes you may not get a reply to your specific questions (or it may take awhile). Just don't get upset if your post goes unanswered and make some nasty remark (as some "former" members, who are no longer with us, have done).
Car: 85 Camaro
Transmission: TH400
Axle/Gears: 9 bolt
THANKS FOR THE HELP GUYS! i guess ill start the trial and error process of tuning..... ill let yall know if i need any more help
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
You can also get TunerPro RT for free and then if you get the bin. files and xdf. files from Moates then I would just get the Ostrich for real time tuning.
Sanjay
Aug 12, 2015 03:41 PM
