Troubles with AFR Tuner
Old Sep 20, 2007 | 01:06 AM
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
I recently downloaded AFR Tuner and attempted to use it. I recived an error message
Error number :339
Description: component "Msflxgrd.ocw or one of its dependencies not correctly registered: a file is missing or invaild
I read the "read me" and moved the MSFLXGRD.OCX to the system32 file and then ran "Regsvr32 c:\windows\system32\msflxgrd.ocx" a prompt popped up telling me that DllRegisterServer in c:\windows\system32\msflxgrd.ocx succeeded.
I ran the program again and the error message popped up again. Has anyone else ran into this problem?
Old Sep 23, 2007 | 09:22 AM
rhuarc31's Avatar
Car: 89 Formula 350
Engine: 409 nitrous' small block
Re: Troubles with AFR Tuner
Yep, finally gave up on it. I also discoverd that if you look it's named slightly different in the downloaded zip file. I tried renaming it to the correct name and still didn't work. finally gave up on it.
Old Sep 23, 2007 | 09:51 PM
884+3's Avatar
Car: 88 irocz
Engine: b2l 350
Transmission: corvette 4+3
Try this file i found on the net. It worked for me on my home computer and my laptop computer running XP Home. It automatically indexes the needed files for you instead of having to do it manually.
File Type: zip
mrbird
Oct 20, 2015 03:43 AM
tmellott89
Oct 14, 2015 02:06 PM
ULTM8Z
Oct 2, 2015 01:25 PM
355tpipickup
Sep 28, 2015 05:50 PM
Lmancha96
Sep 25, 2015 08:11 PM
