> PE, no change - Any ideas?
Old Sep 29, 2007 | 08:03 PM
96HawkCnvt's Avatar
Working with a 730 pcm, S_AUJPV3 and have made some significant changes to PE at higher RPM in an effort to richen things up when it hits PE. I can see it go into PE just fine and it's mid 12's for awhile and then around 3500 it starts to go lean. Even after significant changes I'm seeing no change. Any ideas on what I could be missing? I'm using the "Enrich Power Change to AFR vs. RPM" in TP with the Super_8Dm2.xdf. Logging AFR from an LM-1 so I'm getting a pretty accurate look at it.
Having some other issues as well but will start with this one.
Thanks!
Todd
Old Sep 29, 2007 | 08:09 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Re: > PE, no change - Any ideas?
Do you have a very powerful engine and small injectors? Or maybe very low fuel pressure at high RPMs?
That's what'd I'd check first...
Old Sep 29, 2007 | 08:14 PM
96HawkCnvt's Avatar
Pretty sure the injectors are sized okay but the fuel pressure is certainly worth checking. I'll throw the gauge on there and see what it does at the higher RPMs. Thanks
Todd
Old Sep 30, 2007 | 09:01 AM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
What temp is your PE constant set too.....it will only enable at a certain temperature in the Constants settings..Enrich Power AFR enable Min Temp. If its set to something higher than operating temp of your engine then you need to adjust VE table instead. Oh...that's in TunerPro RT.
Fuel pressure is another idea worth checking out.
Old Sep 30, 2007 | 07:40 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Could just be that the upper VE cellshave not been tuned properly, I'm struggling with the same issue where PE fuel is off the chart so to speak but I'm running lean at higher RPMs.
Raise the cells that have a hard time getting to (just a bit) and try again to see the results.
Old Sep 30, 2007 | 10:34 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Is your min temp set to 80 degree C...that would be 172 degree F so...about Operating temp right there.
Old Oct 1, 2007 | 11:29 AM
JP86SS's Avatar
The temperature setting selects which of the two tables are used for the PE engagement. It will not actually turn PE on/off, just the points where it comes in at are changed in the other table.
There is a low temp table and a high temp table that are shown below.
The variable at $8602 determines which one is used.
Code:
; PWR ENRICH TPS THRESHOLD vs RPM
; FOR NORMAL COOLANT
; *** WOT ***
; TBL = TPS% * 2.56
                           ; VAL     %TPS      RPM
L8603:        .byte  0x80  ;=128,      50       400
              .byte  0x80  ;=128,      50      1200
              .byte  0x80  ;=128,      50      2000
              .byte  0x9A  ;=154,      60      3200
              .byte  0xB4  ;=180,      70      4800
; PWR ENRICH TPS THRESHOLD vs RPM.  FOR HIGH COOLANT
; *** WOT ***
; TBL = TPS% * 2.56
                           ; VAL     %TPS      RPM
L8608:        .byte  0x80  ;=128,      50.0       400
              .byte  0x80  ;=128,      50.0      1200
              .byte  0x26  ;= 38,      14.8      2000
              .byte  0x26  ;= 38,      14.8      3200
              .byte  0x26  ;= 38,      14.8      4800
As I understand it, this allows PE to be engaged sooner with high temps to possibly use additional fuel to cool the chambers.
Old Oct 1, 2007 | 11:53 AM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Code:
; *** WOT ***
; TBL = TPS% * 2.56
                           ; VAL     %TPS      RPM
; *** WOT ***
; TBL = TPS% * 2.56
                           ; VAL     %TPS      RPM
Yea....but what about the Constant....Enrich Power Min. Temp. I just always thought that it was to only allow PE to start at a given temp? Am I wrong here?
Old Oct 1, 2007 | 02:53 PM
96HawkCnvt's Avatar
That was my question too. I did check the constant and it is set at 116 C. According to my log, the car was running at about 88 C (190 F) so if YenkoST's comment above is true then what I saw might make sense. However, wouldn't that conflict with the AFR vs. Temp table? In other words; if the constant is set for 116C, then any setting below 116C in the AFR vs. Temp table wouldn't be used at all.
I'm sure that I'm just missing something simple here but waiting for one of you guys to explain it.
Thanks!
Todd
Old Oct 1, 2007 | 08:03 PM
JP86SS's Avatar
If you are talking about the item at location 8602 then yes.
The Minimum Temp "for use of the high temp table" is what the variable does.
Naming issue is what caused the confusion.
95HawkCnvt,
As far as why you are running lean, Do the fuel psi check when running to be sure. Tape a gauge to the windshield is the best way. (outside of course)
If fuel pressure is ok then add more to the % change per RPM table.
Old Oct 2, 2007 | 05:40 AM
conv90's Avatar
Car: superrammed V
Engine: 396 SBC Speed Density
Axle/Gears: Dana44 3.45
Have you patched the bin with the 8D PW limit calculation?
With bigger injectors constant and big displacement constant this can be the problem.
I really dont know if with the superAUJUP_3 the pacth is in.
-Beppe-
Old Oct 2, 2007 | 09:00 AM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
95HawkCnvt,
So in other words, the Constant only reflects the min temp of PE when Hot.
Old Oct 2, 2007 | 11:38 AM
JP86SS's Avatar
The switchover point for WHEN to use the HIGH TEMP table.
The tables have the TPS% where PE will become active (At a certain RPM level)
Has nothing to do with temperature.
BTW,
S_AUJP V3 has the patch in it.
Old Oct 3, 2007 | 12:29 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Like JP86SS said, PE MODE always happens. The temp. constant determines which PE table to use. A hotter engine uses a richer table for PE.
What is the fuel pressure and injector DC at the lean condition?
Old Oct 3, 2007 | 10:27 AM
96HawkCnvt's Avatar
I'm going to go out & run it to see what happens to FP, but I just checked my log and the base pulse width for the injectors is at approx. 9.2 ms when it starts to go lean and then climbs to about 10 ms and starts going back down to about 9.3. All the while it is getting leaner.
Todd
Old Oct 4, 2007 | 08:13 AM
96HawkCnvt's Avatar
So it looks like fuel pressure is indeed the culprit here. I'm thinking that it may be the filter because it drops to 20 psi immediately on WOT then will go down even further (17 psi before I let off so it didn't go too lean) if you stay in it.
This was an obviously likely scenario but of course I wasn't thinking about it right away. Thanks for the help guys!
Todd
Old Oct 4, 2007 | 08:55 AM
Todd
hoodathunkit?
1992Vortec
Aug 31, 2015 08:05 PM
CORV3TT3
Aug 23, 2015 11:26 AM
86IROC112
Aug 21, 2015 07:20 PM
forstral
Aug 19, 2015 03:20 PM
perZ
Aug 15, 2015 01:17 PM
