new to PROM burning - will this Moates purchase get me started?
Old Oct 4, 2007 | 10:55 AM
torqueaddict's Avatar
Car: 89 GTA
Engine: 5.7 ZZ4 Vortec TPI
Transmission: 7004R
I am eager to get started on PROM burning for my 89 GTA. I read the FAQs, etc... but I wasn't sure on a few items. Here's what I came up with:
1. G1 Memory Adapter ($35)
2. BURN1 Flash-n-Burn USB-Based Chip Programmer ($85)
3. C2 SST 27SF512 Chip (Should be EEPROM) ($5)
I never had an ECM apart, so I don't quite understand how the G1 adaptor can replace the stock chip. Is the stock chip on a stand alone board that has a cable attached? Also, I read something about this making the limp home memcals not work. Also, I think the BURN1 said it can handle EEPROMS so that should be ok but I wasn't sure if the 27SF512 was an EEPROM.
Let me know if you think this should get me burning new chips for my GTA. Thanks for any info !
Old Oct 4, 2007 | 01:29 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: new to PROM burning - will this Moates purchase get me started?
The G1 adaptor plugs in where the MEMCAL usually is. The MEMCAL plugs into the side of the G1, retaining the limp mode NETRES. The 27SF512 is a Flash chip which will work with the Burn1 and your ECM.
Note that your current BIN is 1/4 the size of the '512 chip. So look into how to offset burn or stack the BIN for proper operation.
RBob.
Old Oct 4, 2007 | 01:43 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i use the Burn1 for my car and bought that G1 adapter kit. I dont use those chips tho, i have older style 256 chips, but those will work if you can stack the bins. Tunerpro has a bin stacker thing in the program but i never used it
Steven 86IROC-Z
Mar 28, 2026 06:42 PM
Glowsock
Jul 24, 2025 03:15 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
Bryan F
Aug 18, 2015 02:28 PM
