$58 F50 array
Old Oct 8, 2007 | 03:33 AM
fury pilot's Avatar
Engine: GM 2.0XE
$58 F50 array
Anybody know what the F50 look-up array in $58 is for?
PROMgrammer calls F50 'Bias temp vs COOLTSU' (i.e. CTS at start up).
It seems to be used in closed loop code (where it is added onto whichever is the lowest of: CTS at startup and CTS), but I haven't worked through that yet (and was hoping not to have to, as I plan to always run open loop).
The standard Sunbird version of F50 is a bit weird too. I could maybe understand if the values at one end were all non-zero, and the other end all zero, but they're mixed up.
Old Oct 8, 2007 | 01:38 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: $58 F50 array
It is a strange one, no doubt about it. The turbo GrandAm also has values that vary inconsistently. Here is what I have for the table & section of code:
Code:
        FCB      87     ; -40
        FCB      71     ; -28
        FCB      55     ; -16
        FCB      39     ;  -4
        FCB       0     ;   8
        FCB      63     ;  20
        FCB      47     ;  32
        FCB       0     ;  44
        FCB       0     ;  56
        FCB       0     ;  68
        FCB       0     ;  80
LDC29:  BRCLR   L00C6;$01,LDC33 ; aldl mode 4 command
        BRSET   L00C7;$01,LDC5A ; aldl mode 4 command
        BRA     LDC12           ; bra to reset INT & variables
LDC33:  BRSET   L0024;$20,LDC5A ; MW2, Diagnostic Switch In ALDL Position
        LDAB    L009D           ; su coolant, N = (C + 40) * 256/192
        CMPB    L0034           ; cts, linearized, default/mat on err
        BLS     LDC3F           ;
        LDAB    L0034           ; cts, linearized, default/mat on err
LDC3F:  ADDB    L00F4           ; Coolant Bias for SU CTS
        BCS     LDC47           ;
        BLS     LDC5A           ; bra if SU/CTS+bias <= current CTS
LDC47:  BRSET   L0030;$40,LDC5A ; MWAF1, Rich - Lean Flag (1 = Rich, 0 = Lean)
        CMPA    #128            ; cmp INT & neut
        BCS     LDC5A           ; bra if INT < 128, removing fuel
        BRCLR   L0029;$80,LDC12 ; closed throttle flg, bra to reset INT & variab
        LDAB    L0050           ; mph * 3.2
        CMPB    LC657           ; 1.6 mph, mph * 3.2 thres for low spd VE% tbl
        BCC     LDC12           ; bra if > 1.6 mph to reset INT & variables
        ; test for x-cnt timeout
LDC5A:  LDAB    L0076           ; no x-cnt timer
        CMPB    L0077           ; x-cnt expected timeout
        BLS     LDC87           ;
        BCLR    L0030;$20       ; MWAF1, First Time CIL Flag
        CLR     L0076           ; no x-cnt timer
        ; no x-cnt, move INT
RBob.
Old Oct 13, 2007 | 09:49 AM
fury pilot's Avatar
Engine: GM 2.0XE
Re: $58 F50 array
Thanks.
The Sunbird F50 has the same values.
InfernalVortex
Apr 20, 2021 11:31 AM
lovemymaro
Members Camaros
Dec 21, 2007 11:50 PM
fury pilot
Oct 8, 2007 03:23 AM
Craig Moates
May 1, 2007 12:11 AM
tpi_roc
Jun 12, 2002 03:30 PM
