how to set TCC lock up correctly
Old Oct 17, 2007 | 03:12 PM
avengersteve's Avatar
Car: 1988 firbird formula
Engine: 5.7l pony eater
Axle/Gears: 4.10
$6E ARAP
i wantedt to know if i want my converter to lock at 40 mph, do all i need to do is raise the low spped limit for low gear unlock to lock transition to 40?
reason i ask is my car is "bucking" real bad an i figured out its the converter trying to lock around 35mph and lock at 30mph (during deceleration)
also what about the high gear lock? i think this may be where my problem is, being as it bucks in OD and D
thanks
Old Oct 17, 2007 | 03:39 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: how to set TCC lock up correctly
Check this thread out, good info:
https://www.thirdgen.org/forums/diy-...ad-vs-mph.html
RBob.
Old Oct 17, 2007 | 04:34 PM
Axle/Gears: 4.10
just what i needed, i beleve i had the speeds backward.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
I'llrocya
Exterior Parts for Sale
Nov 11, 2015 05:45 PM
Dialed_In
Aug 20, 2015 01:45 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
