How do I dissable CL in 6E?
Old Oct 27, 2007 | 04:05 PM
Brandon2350's Avatar
Car: 1993 Z-71 pickup
Engine: Heavily modified 355 on TBI
Transmission: Had a 4L60e. Now a 700R4
Axle/Gears: Bone Stock
Can anyone tell me specifically how to dissable closed loop using Cats Tuner w/6E? I'm running out of things to try and I'm stuck.
Old Oct 27, 2007 | 05:40 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Re: How do I dissable CL in 6E?
I have Tunercat and TunerPro RT. I can't find a setting in Cats to do this, but I can in TunerPro. The more I learn, the more I'm using TunerPro instead of Cats.
In TunerPro (free download by the way) there is a "closed loop enable temp" setting and I can go set the temp all the way to 304 deg. That will disable closed loop easily. There are so many more things you can do in TunerPro than in Cats. Give it a try, you will really like it. There is also an expanded 6E definition file floating around here somewhere.
Old Oct 27, 2007 | 07:49 PM
I appreciate that...It might be worth a try
Winchester1094
Sep 15, 2015 09:48 AM
SnoTucker
Jul 6, 2009 08:15 PM
1992rs/ss
Nov 13, 2004 02:23 PM
Z-BOSS
May 23, 2001 03:52 PM
LBSZ28BLOWN
Feb 7, 2001 03:27 PM
