Deleting the narrowband o2 sensor
Old Nov 20, 2007 | 09:39 AM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Running the '730 ecm and tuning by TunerPro RT...I was told to delete the o2 sensor by
8249 bit 6 = Err 13 o2 sensor
824B bit 3 = Err 44 Lean
824B bit 2 = Err 45 Rich
Turn them off, clear your codes and no more light
I want to do this while I'm tuning in open loop and took out the narrowband so that I won't mess it up.
However, I can't find them so I was told I might have to program them in...can anyone do this for me or take a look at my bin. or xdf. files just to make sure I'm not overlooking them. Thanks for the help.
Old Nov 21, 2007 | 12:46 AM
MdFormula350's Avatar
Re: Deleting the narrowband o2 sensor
I just opened up the stock 92gta 350 tpi.bin
using 8d.xdf
I think what you have typed I found under Flags/Switches
Here is what I see that matches what u typed in.
Switch 249 Error Code Masks (12-22) - Bit 6 - 13
Switch 24B Error Code Masks (36-51) - Bit 3 - 44
Switch 24B Error Code Masks (36-51) - Bit 2 - 45
I am sorry if I am not any help, but I havent dealt with the Flags/Switches before.
Old Nov 21, 2007 | 05:24 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
If the switch/flag does not exist in your definition, create it.
Go to the XDF menu and go down to "create a new item"
remember the $8D addressing starts at $8000 so you don't need to enter the 8, just the last 3 will make it correct because the definition is offset by (starts at) $8000 already.
Also if you are not looking at the item summary listing, hit "F7" or select it from the "View" menu.
Sort the list by address. They are all in numeric order so you can see if they actually exist before adding a new entry.
Old Nov 22, 2007 | 12:45 AM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
using 8d.xdf
You are the man...thanks for the translation...I do have them...just didn't know to look for the last three digits(Thanks JP86SS)
Frozer!!!
Jan 19, 2024 04:55 PM
86White_T/A305
Sep 21, 2015 05:28 PM
nuggie
Aug 25, 2015 01:27 PM
Grumpy
Mar 10, 2004 03:46 PM
